ml6156
May 22, 2024Tutor
C7100v with Xfinity voice (reboots on some calls)
I have Xfinity Internet & Voice service, with 1 line connected to the TEL1 port.
Intermittently, I will receive a call with one ring only, (no caller ID or call history saved), which reboots the router.
I've discovered that this happens when the phone has no dial tone. This started infrequently, first every week or so, increasing to several times a week.
I've worked with both Xfinity and Netgear support for 9 months now. Lines have been checked, cables changed, telephone changed, etc. It was determined there was a hardware issue with the TEL port on the modem and the proposed resolution was to replace the C7100v, which I did.
I installed the new modem on 5/2 and it has been working fine until today when I noticed there was no dial tone. I called the number from my cell and it caused a reboot, as expected.
Has anyone else using a C7100v and Xfinity voice seen this issue? I found on post on reddit with this issue, but there were no replies. All techicians state they have never heard of anything like this and they're at a loss.
Any suggestions would be most appreciated. Thanks.
- KitsapMaster
ml6156 wrote:I have Xfinity Internet & Voice service, with 1 line connected to the TEL1 port.
Do you have the NOMOROBO service configured for your Xfinity number? Might be some issues there.
The NOMOROBO service is included with your Xfinity phone service.
- ml6156Tutor
Thanks, I just double checked, and I don't have NOMOROBO service on this line. Maybe I should considering that's the bulk of calls. I could spend hours blocking numbers.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
