Lrmcneil's avatar
Lrmcneil
Follower
Aug 14, 2019
C7800
During initial setup, must the modem user name stay ‘ADMIN’ or can I change it?
1 Reply
  • FURRYe38's avatar
    I don't believe you can change it. You can try to see if there is any settings under Advanced/Advanced Settings/Administration. If not, then you can't.
