yoshiki3x's avatar
yoshiki3x
Follower
Aug 01, 2024
CBR750 Coax connector too thick
Hi there, I just got a cbr750 from ebay. However, after unplugging my old equipment, i cannot make the cable fit into this connector. The coax connector in the cbr750 seems too thick for the cable coming from the wall. Are there any adapters I can buy? Was this modified?
  • FURRYe38's avatar
    You sure? Looks like it might be a tight fit however can you get the screw to go around the coax connector on the CBR?
    Look on online for RJ6 coax adapters or a short coax extender.
    Can ask the ISP to put a different coax connector on if they can.
    • plemans's avatar
      that looks correct. I've got the same type end connector on my cable. Its a tight fit but works
