m03bius's avatar
m03bius
Follower
Jul 08, 2024
CBR750 SNMP Support?
I see in the product documentation that SNMP is disabled by default on the CBR750 under the LAN settings.  How do I enable it?  I see RIP, DHCP, and basic networking config, but nothing for SNMP.  How do I enable it?
Thanks!
1 Reply
  • FURRYe38's avatar
    I don't believe SNMP is supported on the CBR. If you don't see any WEB UI options for this, then would not be available.
