Orbi WiFi 7 RBE973
Reply
CM 1000 T3 and T4 connection timeouts persistent for years now?
johnj7
There are a number of similar posts and messages in this support forum regarding the same connection issues with the Netgear CM1000 DOCSIS 3.1 cable modem.  It seems that the issues persist even years after the initial problems were detected and, allegedly, resolved through firmware updates.  According to the support --> firmware/software page, I have the latest firmware version installed by my ISP (RCN).  However, the same connection issues are seen in the event logs as the other related forum threads here.  The problems were not there while I was leasing a modem from the ISP.
Time 	Priority 	Description
2019-07-11, 06:12:30	Warning (5)	REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-11, 06:12:25	Notice (6)	DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 .;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-11, 06:12:16	Error (4)	Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-11, 06:12:16	Error (4)	Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-11, 06:12:16	Error (4)	Missing BP Configuration Setting TLV Type: 17.7;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-11, 06:12:16	Error (4)	Missing BP Configuration Setting TLV Type: 17.6;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-11, 06:12:16	Error (4)	Missing BP Configuration Setting TLV Type: 17.5;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-11, 06:12:16	Error (4)	Missing BP Configuration Setting TLV Type: 17.4;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-11, 06:12:16	Error (4)	Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-11, 06:12:16	Error (4)	Missing BP Configuration Setting TLV Type: 17.2;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-11, 06:12:16	Error (4)	Missing BP Configuration Setting TLV Type: 17.1;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
Time Not Established	Warning (5)	DHCP WARNING - Non-critical field invalid in response ;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
Time Not Established	Notice (6)	Honoring MDD; IP provisioning mode = IPv4
Time Not Established	Critical (3)	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 23:02:13	Critical (3)	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
Time Not Established	Critical (3)	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:13:55	Critical (3)	No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:13:45	Critical (3)	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:13:35	Critical (3)	Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:13:15	Critical (3)	Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:08:51	Critical (3)	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:08:31	Critical (3)	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:06:57	Critical (3)	No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:06:56	Critical (3)	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:06:39	Critical (3)	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:06:26	Critical (3)	Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:05:59	Critical (3)	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:05:51	Critical (3)	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:05:40	Critical (3)	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:05:35	Critical (3)	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:05:30	Critical (3)	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:05:20	Critical (3)	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:03:17	Critical (3)	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:02:47	Critical (3)	Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
2019-07-10, 21:02:30	Critical (3)	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:a5:83:48;CMTS-MAC=00:af:1f:1e:b4:ea;CM-QOS=1.1;CM-VER=3.1;
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 5
Guru
Re: CM 1000 T3 and T4 connection timeouts persistent for years now?
Something to have your ISP review with you to see if there is any issues.
Be sure ISP checks signal line quality and levels up to the modem.
Be sure there are no coax cable line splitters inbetween the modem and ISP service box.
Message 2 of 5
johnj7
I only have Internet service; i.e. single coax line.  I did call to make sure the modem was provisioned correctly after I kept noticing service interruptions.  Aside from the modem itself, I don't see anything else that's changed.
Message 3 of 5
johnj7
Additionally, I've also noticed the logs show warnings about dynamic range window violations.
The pertinent downstream/upstream info:
Upstream Bonded Channels
Channel 	Lock Status 	Modulation 	Channel ID 	Frequency 	Power
1	Locked	ATDMA	4	36800000 Hz	27.5 dBmV
2	Locked	ATDMA	5	30350000 Hz	27.0 dBmV
3	Locked	ATDMA	6	23900000 Hz	26.5 dBmV
4	Not Locked	Unknown	0	0 Hz	0.0 dBmV
5	Not Locked	Unknown	0	0 Hz	0.0 dBmV
6	Not Locked	Unknown	0	0 Hz	0.0 dBmV
7	Not Locked	Unknown	0	0 Hz	0.0 dBmV
8	Not Locked	Unknown	0	0 Hz	0.0 dBmV
Downstream OFDM Channels
Channel 	Lock Status 	Modulation / Profile ID 	Channel ID 	Frequency 	Power 	SNR / MER 	Active Subcarrier Number Range 	Unerrored Codewords 	Correctable Codewords 	Uncorrectable Codewords
1	Locked	0, 255	159	651000000 Hz	18.4 dBmV	33.3 dB	646 ~ 3449	1906011210	1481183335	824
2	Not Locked	0, 255	0	0 Hz	3.4 dBmV	0.0 dB	0 ~ 4095	0	0	0
Upstream OFDMA Channels
1	Not Locked	Unknown	0	0 Hz	0 dBmV
2	Not Locked	Unknown	0	0 Hz	0 dBmV
Message 4 of 5
Guru
Something to ask the ISP about...
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1909 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
