FugazziFix
Aug 26, 2023Aspirant
CM1000v2
Hello, It appears that my cable modem has failed. Is there any service that repairs them or is this a throwaway item.
The modem just flashes all lights in amber continuously.
Thanks Dave
dflugstad@gmail.com
Even after a 10 second press of the reset button or a 30-30-30 reset? If so, time for a new one.
- FugazziFixAspirant
Thx for the reply. What's the 30-30-30 function? Can you direct me to where that is documented?
Thanks Dave
https://www.lifewire.com/hard-reset-rule-for-routers-3971318
Do this with the modem disconnected from the ISP coax cable line.
