× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
× NETGEAR would like to hear from you about specific features so we can improve your experience. To participate in this survey please click HERE.
Reply
CM700 blinking upstream light
Hallywood
This has happened before and took hours before it magically started working again. Called Comcast, my ISP, and of course they claim everything looks good on their end. Netgear support is a rip off and won’t deal with them. I have checked the cables going to and from the modem and router the best I can and do not see any issues or loose connections. I attached the downstream channels from Netgear genie and will try to attach more photos soon.
Message 1 of 8
Hallywood
Re: CM700 blinking upstream light
Here are the downstream channels. I do not know how to interpret what any of these channels mean.
Message 2 of 8
Hallywood
Here are the upstream channels.
Message 3 of 8
Guru
Power is kind of all over the place and some are a bit running on the high end of power for the downstream:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Please post a copy and paste of the modems event log page.
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 4 of 8
Hallywood
And finally here is the event log. Comcast claims there is no issue on their end and that a technician needs to look at the modem. I don’t believe that to be true.
Message 5 of 8
Hallywood
I have checked all connections inside the house. No loose connections, kinks, or anything of the sort. The modem is a Netgear CM700 and the router is a Netgear AC1200 model R6220.
Message 6 of 8
Guru
Lots of errors in the logs.
If you've checked everything on your side, then xfinity does need to check the line.
they always do say on first response "it isn't our line"
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 7 of 8
Guru
Ya those criticals need to be reviewed and resolved by the ISP.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 248 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
