Ted2022
Sep 11, 2022Aspirant
CM700 in and out connection issue
I have been having in and out connectivity issues lately. I have read some of the past postings but I'm not sure how I can solve it.
Could someone please help me?
I am very dim on internet connection and pc related topics so if you can be so kind to explain in a way that a dummy like myself could understand, it would be really appreciated!
For upstream bonded channels, it shows only 4 being used. From other postings I see all the 8 being used, does this have anything to do with the issue I am having??
Any help would be really appreciated! Thank you in advance!!
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Ted2022Aspirant
I forgot to mention, WOWWAY tech support told me to contact the modem manufacturer to change 2.4Ghz and 5 Ghz channels.
Does this mean anything to you guys?
Thanks!
Power and Correct and Uncorrectables look fine.
However you have Criticals and Errors in the event log. Something that the ISP needs to review and resolve.Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/The CM700 is a modem only. No built in router or wifi here.
- Ted2022Aspirant
Thanks for your reply!
The host wifi router connected to the modem is Deco AC1300. I will need to replace the cable between the modem and the router with CAT6.
Regarding the connection up to the modem, I need to check with WOW.
WOW was blaming the modem not correctly channeling between 2.4 and 5.0Ghz, but I will check with them again.
Turning off and on the modem I have tried but I still get this issue...
Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 12 2022 17:11:43 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option Thank you again for your reply and guidance!
"WOW was blaming the modem not correctly channeling between 2.4 and 5.0Ghz" < Be sure they understand and you understand that this model modem does NOT have a built in route or wifi.
Also those errors and criticals in the event log needs to be reviewed at addressed by the ISP.
