band_of_gypsys's avatar
May 12, 2024
Internet constantly losing connection - Multiple Errors Reported by my Netgear CM1000v2 Cable Modem
Xfinity Internet - 500Mbps Download Package
Netgear - CM1000v2 - Cable Modem - (Firmware v10.01.07)
Internet has been fine for over 4 years, last week connection started to drop out every 2 hours or so. Now it's dropping every 5-10 minutes.
I only use wi-fi for phone etc, everything else is wired. I lose both LAN and wi-fi.
No splitters, all new cables. I first thought it might be the router (Netgear xr300) so I plugged my computer directly into the modem. Did not solve the issue.
Logs and Connection Stats are as follows:
TimePriorityDescription
2024-05-12, 20:09:23Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;
2024-05-12, 20:08:55Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.
2024-05-12, 20:08:08Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;
2024-05-12, 19:39:31Critical (3)UCD invalid or channel unusable;
2024-05-12, 19:39:31Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;
2024-05-12, 19:39:20Notice (6)Honoring MDD; IP provisioning mode = IPv6
2024-05-12, 19:39:15Critical (3)UCD invalid or channel unusable;
2024-05-12, 19:38:55Notice (6)Honoring MDD; IP provisioning mode = IPv6
2024-05-12, 19:38:41Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;
2024-05-12, 19:30:37Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;
2024-05-12, 19:29:37Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;
2024-05-12, 19:19:24Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out
2024-05-12, 19:18:41Warning (5)Dynamic Range Window violation
2024-05-12, 19:18:41Warning (5)RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;
2024-05-12, 19:14:29Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;
2024-05-12, 19:10:21Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;
2024-05-12, 19:06:03Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;
2024-05-12, 19:06:03Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;
2024-05-12, 19:03:07Critical (3)UCD invalid or channel unusable;
2024-05-12, 19:03:07Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;
2024-05-12, 19:02:57Notice (6)Honoring MDD; IP provisioning mode = IPv6
2024-05-12, 19:02:52Critical (3)UCD invalid or channel unusable;
2024-05-12, 19:02:30Notice (6)Honoring MDD; IP provisioning mode = IPv6
2024-05-12, 19:02:19Critical (3)SYNC Timing Synchronization failure - Loss of Sync;
2024-05-12, 19:01:44Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;
2024-05-12, 19:01:38Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;
2024-05-12, 19:01:38Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;
2024-05-12, 19:01:37Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;
2024-05-12, 19:00:57Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;
2024-05-12, 19:00:54Warning (5)MDD message timeout;
2024-05-12, 19:00:49Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;
2024-05-12, 19:00:45Warning (5)MDD message timeout;
2024-05-12, 19:00:45Notice (6)CM-STATUS message sent. Event Type Code: 2; Chan ID: 24 26; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;
2024-05-12, 18:51:56Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;
2024-05-12, 18:48:58Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;
2024-05-12, 18:47:03Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;
2024-05-12, 18:40:16Warning (5)Dynamic Range Window violation
2024-05-12, 18:40:16Warning (5)RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;
2024-05-12, 18:39:44Critical (3)UCD invalid or channel unusable;
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel711000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnableBPI+
IP Provisioning ModeHonor MDDIPv6 only
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1LockedQAM25644711000000 Hz12.3 dBmV43.9 dB2063251107842361
2LockedQAM25613525000000 Hz12.3 dBmV44.4 dB20346072249588837
3LockedQAM25614531000000 Hz12.0 dBmV44.3 dB213547814130599223
4LockedQAM25615537000000 Hz11.8 dBmV44.1 dB2034118211263914272
5LockedQAM25616543000000 Hz11.9 dBmV44.4 dB213606604136668413
6LockedQAM25617549000000 Hz12.3 dBmV44.5 dB203461579678811153
7LockedQAM25618555000000 Hz12.1 dBmV44.3 dB213613852833513884
8LockedQAM25619561000000 Hz12.0 dBmV44.2 dB20350266840538409
9LockedQAM25620567000000 Hz12.2 dBmV44.3 dB20333653011243219
10LockedQAM25621573000000 Hz12.5 dBmV44.6 dB203348812678123883
11LockedQAM25622579000000 Hz12.4 dBmV44.4 dB2033564927321760
12LockedQAM25623585000000 Hz11.9 dBmV44.1 dB203518138857014595
13LockedQAM25624591000000 Hz12.0 dBmV44.0 dB2033765848122573
14LockedQAM25625597000000 Hz12.6 dBmV44.4 dB2034517382219833752
15LockedQAM25626603000000 Hz12.6 dBmV44.4 dB2033950428382305
16LockedQAM25627609000000 Hz12.0 dBmV44.0 dB2135661602647534354
17LockedQAM25628615000000 Hz11.8 dBmV43.9 dB21371180388417837
18LockedQAM25629621000000 Hz12.4 dBmV44.2 dB213701708983521587
19LockedQAM25630627000000 Hz12.5 dBmV44.4 dB203571765833219209
20LockedQAM25631633000000 Hz12.0 dBmV44.1 dB21374058662107879
21LockedQAM25632639000000 Hz11.8 dBmV43.9 dB20363505938713688
22LockedQAM25633645000000 Hz12.0 dBmV44.1 dB21376467339948665
23LockedQAM25634651000000 Hz12.3 dBmV44.4 dB20364158237258396
24LockedQAM25635657000000 Hz11.8 dBmV44.2 dB21377865751457024
25LockedQAM25636663000000 Hz11.2 dBmV43.7 dB20365603931757285
26LockedQAM25637669000000 Hz11.2 dBmV44.0 dB21380274231924992
27LockedQAM25638675000000 Hz11.9 dBmV44.1 dB20367332461197038
28LockedQAM25639681000000 Hz11.8 dBmV44.2 dB21382099641324950
29LockedQAM25640687000000 Hz11.2 dBmV43.8 dB20369797233876287
30LockedQAM25641693000000 Hz11.0 dBmV43.5 dB20372318067605507
31LockedQAM25642699000000 Hz11.5 dBmV43.8 dB20373993744646159
32LockedQAM25643705000000 Hz11.8 dBmV44.1 dB20375848636043564
Upstream Bonded Channels
1LockedATDMA1716400000 Hz48.3 dBmV
2LockedATDMA1822800000 Hz45.3 dBmV
3LockedATDMA1929200000 Hz47.8 dBmV
4LockedATDMA2035600000 Hz48.5 dBmV
5Not LockedUnknown00 Hz0.0 dBmV
6Not LockedUnknown00 Hz0.0 dBmV
7Not LockedUnknown00 Hz0.0 dBmV
8Not LockedUnknown00 Hz0.0 dBmV
Downstream OFDM Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1Locked0, 1, 2, 3193957000000 Hz14.6 dBmV43.8 dB148 ~ 39475150746660516817578
2Not Locked000 Hz7.9 dBmV0.0 dB0 ~ 4095000
Upstream OFDMA Channels
1Not LockedUnknown00 Hz0 dBmV
2Not LockedUnknown00 Hz0 dBmV
