HellKtty81's avatar
HellKtty81
LOW download speeds
just bought this was getting 950 Mbps with a modem then hooked to a router now varying from 80 -600 then falls flat to around 80 what could cause this ? comcast is my internet service provider . did i get the wrong one for comcast ? i about had it with this one if it keeps it up im returning it going back to my old set up
  • apparently it fixed it self must have had a driver or something was screwing it up
  • plemans's avatar
    It should hit gigabit without issues.
    How are you testing the speeds?
    Wired? Wireless?
    What site are you using for testing?
    got a copy of the cable connections page and event logs?
    • HellKtty81's avatar
      HellKtty81
      i use ookla with new pc a ultra 9 285k with a rtx 5080 2 4 TB SSD with wifi 7 with a asus z890 hero motherboard is on ethernet on the 5G port on the ax2700 its the same using the 2.5 G port as well but i get the same result on my phone when i test it on netgear app plus when i had my old equipment had a arris s33 modem then a asus wifi router would get 949 Mbps constantly with no issues on the same sites .
      • plemans's avatar
        got a copy of the cable connections page (shows upstream/downstream values) and event logs?
        those help check the line, Wouldn't be the first time something had gotten tightened wrong or caused a cable issue
