swinc55
Jul 19, 2023Follower
Looking to replace a C6250. Think I took a power surge
It halfway works. It's a Combo Modem Router Wifi
What an upgrade that's reliable without breaking the bank. Im not a gamer or anything so dont need super high speed.
Adding a MK MESH system in AP mode would be a nice upgrade.
What speeds do you pay for?
What size is your home?
What is your budget?
Are you looking for a combo device or a modem separate from a router?
Details are key.
Are you wanting to keep the c6250? Or you could put it in modem only mode and just get a router.
