fakotto
Oct 16, 2023Follower
Losing connection with CM1000v2 repeatedly all week
Hey all. I have been experiencing issues with my network the last week. Throughout the day, I will lose connection, or get really high spikes of latency repeatedly.
Current setup:
Netgear CM1000v2 modem
TP-Link Archer AX11000 router
I don't have any splitters. Typical setup. Modem to router, router to desktop PC. The whole network goes down, Wi-Fi and wireless. I've provided logs of my modem for you to see.
Checked ethernet cable. No kinks. High quality Cat6 cable from Monoprice. No changes to setup or network. Been running smooth for close to 2 years with this set up.
Side note: I don't know where modem gets time and date from, but it is incorrect. However on my router, it is correct. Modem dashboard doesn't show any settings where I can change the time.
Getting multiple T3 and T4 time outs:
Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-
Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Just lost connection 5-6 times, and modem logs show this:
2023-10-14, 17:39:41 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:39:39 Error (4) DBC-ACK not received;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:39:17 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:38:09 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:36:39 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:36:38 Error (4) DBC-ACK not received;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:36:36 Warning (5) TCS Partial Service;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:34:05 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:34:04 Error (4) DBC-ACK not received;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:34:03 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:34:02 Warning (5) DBC-REQ denied - confirmation code 209: reject-bad-tcc;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:33:07 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:33:01 Error (4) DBC-ACK not received;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:28:37 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:28:30 Warning (5) DBC-REQ denied - confirmation code 209: reject-bad-tcc;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:27:43 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:27:29 Error (4) DBC-ACK not received;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:26:21 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:26:20 Warning (5) DBC-REQ denied - confirmation code 209: reject-bad-tcc;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:25:22 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:25:19 Error (4) DBC-ACK not received;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:25:10 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:25:10 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:25:00 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:25:00 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:24:54 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:24:53 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:24:52 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:24:51 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:24:48 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:24:48 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:24:47 Warning (5) TCS Partial Service;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:24:19 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:23:47 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:12:45 Error (4) DBC-ACK not received;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:12:43 Warning (5) DBC-REQ denied - confirmation code 209: reject-bad-tcc;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
2023-10-14, 17:11:42 Error (4) DBC-ACK not received;CM-MAC=44:a5:6e:b9:16:58;CMTS-MAC=00:90:f0:46:01:00;CM-QOS=1.1;CM-VER=3.1;
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords
1 Locked QAM256 4 417000000 Hz 3.4 dBmV 42.3 dB 2753437363 0 0
2 Locked QAM256 1 399000000 Hz 3.1 dBmV 42.3 dB 2752489669 0 0
3 Locked QAM256 2 405000000 Hz 3.2 dBmV 42.4 dB 2752478642 0 0
4 Locked QAM256 3 411000000 Hz 3.3 dBmV 42.3 dB 2752496400 0 0
5 Locked QAM256 5 423000000 Hz 3.5 dBmV 42.4 dB 2752497868 0 0
6 Locked QAM256 6 429000000 Hz 3.5 dBmV 42.4 dB 2752501337 0 0
7 Locked QAM256 7 435000000 Hz 3.6 dBmV 42.3 dB 2752508372 0 0
8 Locked QAM256 8 441000000 Hz 3.6 dBmV 42.3 dB 2752508499 0 0
9 Locked QAM256 9 447000000 Hz 3.6 dBmV 42.4 dB 2752514260 0 0
10 Locked QAM256 10 453000000 Hz 3.6 dBmV 42.2 dB 2752521337 0 0
11 Locked QAM256 11 459000000 Hz 3.6 dBmV 42.1 dB 2752525626 0 0
12 Locked QAM256 12 465000000 Hz 3.7 dBmV 42.3 dB 2752530361 0 0
13 Locked QAM256 13 471000000 Hz 3.7 dBmV 42.3 dB 2752533007 0 0
14 Locked QAM256 14 477000000 Hz 3.7 dBmV 42.3 dB 2752535877 0 0
15 Locked QAM256 15 483000000 Hz 3.7 dBmV 42.5 dB 2752537947 0 0
16 Locked QAM256 16 489000000 Hz 3.7 dBmV 42.5 dB 2752541816 0 0
17 Locked QAM256 17 495000000 Hz 3.4 dBmV 42.4 dB 2752544355 0 0
18 Locked QAM256 18 507000000 Hz 3.2 dBmV 42.4 dB 2752547927 0 0
19 Locked QAM256 19 513000000 Hz 3.2 dBmV 42.5 dB 2752552449 0 0
20 Locked QAM256 20 519000000 Hz 3.0 dBmV 42.4 dB 2752558736 0 0
21 Locked QAM256 21 525000000 Hz 3.0 dBmV 42.4 dB 2752561635 0 0
22 Locked QAM256 22 531000000 Hz 2.9 dBmV 42.3 dB 2752565418 0 0
23 Locked QAM256 23 537000000 Hz 2.8 dBmV 42.2 dB 2752570285 0 0
24 Locked QAM256 24 543000000 Hz 2.7 dBmV 42.3 dB 2752573404 0 0
25 Locked QAM256 25 549000000 Hz 2.7 dBmV 42.3 dB 2752574848 0 0
26 Locked QAM256 26 555000000 Hz 2.8 dBmV 42.5 dB 2752579960 0 0
27 Locked QAM256 27 561000000 Hz 2.6 dBmV 42.3 dB 2752583615 0 0
28 Locked QAM256 28 567000000 Hz 2.6 dBmV 42.3 dB 2752587413 0 0
29 Locked QAM256 29 573000000 Hz 2.5 dBmV 42.3 dB 2752589840 0 0
30 Locked QAM256 30 579000000 Hz 2.5 dBmV 42.2 dB 2752595795 0 0
31 Locked QAM256 31 585000000 Hz 2.5 dBmV 42.2 dB 2752595140 0 0
32 Locked QAM256 32 591000000 Hz 2.7 dBmV 42.2 dB 2752601777 0 0
No RepliesBe the first to reply
