Orbi WiFi 7 RBE973
Reply
Modem CM2000 Hard Wired Network Port Not Sending Signal
t3chladyFL
Follower
I recently changed my network power source to come from a UPS and in the process I powered down all equipment, installed the UPS and plugged in the modem, router and computer.  I turned on the modem (the CM2000) and it appeared to initialize correctly.  I plugged in the router but the router did not see the internet connection.  I troubleshooted by plugging in my computer directly to the CM2000 but the computer did not see the internet connection either.  As anyone ever experienced this ?  I tried multiple restarts, calling my internet provider and going through countless troubleshooting steps with no success.  The modem was purchased this past April.
Message 1 of 2
Kitsap
Master
Re: Modem CM2000 Hard Wired Network Port Not Sending Signal
Many people have found themselves in your spot.  The initialization sequence is important.
Power down your computer.  If it is a desktop, disconnect the power cord.
Power down your router and disconnect the power cord.
Power down your modem (pull the power cord), disconnect both the coax cable and the output Ethernet cord.
Take a breath, connect the coax cable to your modem and connect the power cord.  Give your modem ample time to boot and to connect to your ISP and stabilize.  Look at the LEDs on the front.  Internet indicator should be on and solid.  Only the multi-gig should be flickering.
Connect the Ethernet output from your modem to the WAN input on your router.  Connect the power cord and boot up your router.  Give it ample time to boot and stabilize.  The router indicator showing internet connection should be one of the last indicators to stabilize.
Power on your computer and you should be good to go.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 618 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
