Quiksilverhg's avatar
Quiksilverhg
Follower
Dec 11, 2018
N600 AC adapter
I have had a Netgear N600 for a few years. After being in a box for a couple years, I pulled it out again after switching cable companies and the AC adapter has wandered off. Can I order a new AC adapter from Netgear, or is there another compatible one I can find?
1 Reply
  • > I have had a Netgear N600 [...]
       "N600" is a speed, not a model number.  Ever helpful, Netgear
    product packaging emphasizes speeds like "Nxxx", but that's not the
    model identifier.  Look at the product label.
    > Can I order a new AC adapter from Netgear, [...]
       I've never seen a way to get parts from Netgear.
    > [...] or is there another compatible one I can find?
       Ebay?
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual.  Get the power adapter
    ratings from the technical specifications, and start looking for
    something suitable?  Gauging the connector dimensions can be a bit
    tricky.
