jimcooked's avatar
jimcooked
NIGHTHAWK CAX30 WON'T FACTORY RESET. 1234 LEDs LIT
Help, my nighthawk is down. I've been holding the factory reset for 30 secs, powering down for 30s, and restarting with the factory reset held down for 30s.... nothing.
LEDs, "1, 2, 3, 4" are lit. Modem is unresponsive via LAN.
  • FURRYe38's avatar
    Is this done with the ISP coax line disconnected from the modem?
    • jimcooked's avatar
      jimcooked
      tried with coax connected, and without. same results
      • FURRYe38's avatar
        If the front POWER LED and the Link Down and Up LEDs are not coming on, seems like CAX is bad. Something to contact NG support about and see what your options are.
