Orbi WiFi 7 RBE973
Reply
Netgear AC1750 router with Arris TM3402A modem no wifi internet
Fuzzee
Just installed Cox internet. Using Netgear AC1750 router with Cox provided Arris modem model TM3402A. After everything loads up, router internet led blinking green. Try to connect & get "No Internet" msg. Have rebooted multiple times. WiFi enabled. If I reboot and use ethernet cable connection to router get same results. However, if I reboot and connect with ethernet cable directly to Arris modem, connection is good. Any help will be greatly appreciated.
Message 1 of 4
Accepted Solutions
Fuzzee
Re: Netgear AC1750 router with Arris TM3402A modem no wifi internet
Cox rep fixed problem. Modem was replaced and new passwords were required.
Message 3 of 4
All Replies
Guru
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
Message 2 of 4
Fuzzee
Message 3 of 4
Guru
Thanks for letting us know. Glad the new modem is working.
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5004 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
