Shyrage's avatar
Shyrage
Netgear C3700 (N600)
I have this modem/router just laying around and I wanted to go ahead and make use of it again.  I was curious if I could use this as just a wifi extender since I already have a main router/modem from my internet provider Grande.  Any way of making this happen? Any help would be nice, just tell me what I need to do, thanks!!
  • > [...] if I could use this as just a wifi extender [...]
       That depends on what "a wifi extender" means to you.  You should be
    able to configure it as a wireless access point (with a wired connection
    to the main router).  See, for example:
          https://community.netgear.com/t5/x/x/m-p/1463500
       That's written for a C6300, but the steps are about the same for any
    other router (any make/model) which lacks a one-step WAP option,
    including yours.
    • Shyrage's avatar
      Shyrage
      Ok, so I can't use as a wireless access point like my old Rangemax wireless router WPN824 v3?  What I mean is that I'm using this C3700 on the other side of the home.  There's no way a long line of Ethernet can run from that room all the way to the living room where the main Modem is.  Can't I just plug it into a switch or something?  What changes on the device itself should I be making for the setup?
      • antinode's avatar
        antinode
        Guru
        > wireless router WPN824 v3? [...]
           Do I know what you did with your "my old Rangemax wireless router
        WPN824 v3"?  (Hint: No.)
           Does your "my old Rangemax wireless router WPN824 v3" have a
        WAN/Internet Ethernet port? (I'd assume yes.)  Does your C3700 have a
        WAN/Internet Ethernet port?  (I'd assume no.)  So, can you directly
        substitute a C3700 for a WPN824v3?  Not in all cases.
        > [...] What I mean is [...]
           You lost me.  What, exactly, do you think that you can or can't do
        (and why)?
        > [...] Can't I just plug it into a switch or something? [...]
           Plug what into what?  Why?
        > [...] What changes on the device itself should I be making for the
        > setup?
           If "the device itself" means the C3700, then that depends on what you
        intend to do with it.  If you want to use it as a wireless access point
        (which, I'd expect, is about the only thing which you could do with it),
        then that's what that cited thread tries to explain.
