Allen_Lee's avatar
Feb 05, 2023
New CM500 modem, Online Green Light will not come on at all
  • Turns out the cable had been disconnected inside of the junction box outside of my townhome.  All of the neighbors' cables were okay; mine was the only one that was messed up.  A technician from Xfinity diagnosed the problem.  I have no idea when or why or by who the cable was disconnected, but the technician pointed out that the cable junction box has no lock on it.  I am pondering how to remedy that vulnerability!  Anyway, I am now up and running.  Yippie!
    A couple of obvious questions.  Are you sure your have a signal at the coax cable connection?
    Have you activated your modem with your ISP?
    • Allen_Lee's avatar
      Allen_Lee
      Tutor
      As far as I knew, the connection was good, but I am now guessing it is bad.  I am in a townhome community (rental property) and I do not know whose cable it really is.
      • Kitsap's avatar
        Kitsap
        Master
        Knowing whether or not the cable is hot and knowing who the service provider is are key questions.  There may be other cable outlets in the town-home you can test.  Your modem may not be supported by the service provider.  Also the cable/internet service may be provided as part of your rent payment with details available from the landlord.
