paulast2's avatar
paulast2
Nighthawk AC1900 Wifi Cable Modem Router
So I received an email from Comcast/Xfinity stating I need to update my modem. I just got this modem about 4-4 1/2 years ago when I bought my house and I use it for Streaming TV and working from home (its only myself and my 2 younger kids at home, so not a lot of traffic on it). I know this modem/router was released in 2013 and due to its age is no longer being sold, but still receives update. The specifics on this is Netgear Model #C7000 Nighthawk AC1900 Wifi Cable Modem Router with Built in DOCIS 3.0 Cable Modem, up to 960 Mbps and 23x8 channel bonding. I have recently noticed lagging (not a lot) when streaming and when working I've noticed there are times when Im working in Outlook (via my company worksite) that it freezes, but assumed it was something to do with my worksite (cuz it generally is). My Comcast internet info is Download speed up to 1000 Mbps, Upload speed is up to 20 Mbps. Do I need a new modem or do I need to update my Xfinity plan? I just did a "diagnoses check" on Xfinity and it said that everything is fine. I also have to say I did not install this, that the Xfinity guy set this up for me when I moved in 4-4 1/2 years ago, so I'm kind of clueless when it comes to this stuff. If I do need to replace my modem/router, what is recommended?
  • FURRYe38's avatar
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    Yes may need to update the modem. It's up to ISPs to set policy on modem use on there networks. They also are responsible for modem updates and can choose not to update the FW on user owned gateways like the C series.
    NG doesn't product any more C series modems. CAX series is the most current.
  • plemans's avatar
    Xfinity loves to push people to new devices. While that modem won't hit the speeds you're paying for (they require docsis 3.1 for 1 gig plans), it'll still hit 800mbps without issues over wired. It won't hit this over a wireless connection (being an older/slower wireless device).
    Are you wanting to hit the full speeds you pay for? Or did you get it on promotion and you're speeds are fine?
    If you're upload is only approved for the 20mbps, you're not on the "next gen" area yet but that's probably coming.
    You can see their approved devices for and tiers here:
    https://assets.xfinity.com/assets/dotcom/projects/cix-4997_compatible-devices/2024.08.14%20Full%20List%20of%20Compatible%20Devices.pdf
    Are you wanting to upgrade? Or what is your goal (not comcasts)?
    • My goal is not to purchase a comcast router and I would like to hit the wifi speeds that I pay for. I dont want to do wired if I can help it. So by what you are saying I should probably upgrade. I researched and the updated replacement for my current modem/router I have is the CAX80. I just hate to spend that kind of money as Ive priced it and its like almost $400 and thats buying at Walmart. Amazon and other places (even Netgears site) is more expensive. Ugh!!!!
      • FURRYe38's avatar
        Something else to consider as well, get a separate cable modem and external wifi router system.
        ISP update modems only and users can not so this avoids issues seen with some gateways that are combo units with some ISPs. Let the ISP handle the modem and then you can manage that external wifi router system yourself.
        Can be a bit cheaper this way as well. If you don't mind used systems, places like amazon, or shopgoodwill have good used router systems that you can get for cheap. Just gotta look. Maybe a good used modem as well. I found used stuff at these two places for good prices.
