Retired_Member
Sep 13, 2024Nighthawk AX2700
Just purchased a Nighthawk AX2700.
I'm having issue with the Netgear Genie, stating that my wifii connection status is not enable.
How do I enable it?
1 Reply
The Genie app? Genie app isn't supported on the CAX series modems. Genie app is EoL.
The Nighthawk app is supported.
Try using a web browser on a PC or laptop.
