- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk CM1100
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just purchased the Nighthawk CM1100 to get gigabit speeds and dual ethernet links for my own network traffic.
On the one ethernet jack, I have connected my wifi network, and everything is working well enough there with a private internal IP assignment.
On the second ethernet port, I am able to pull a private IP to my laptop, and can connect to the internet through the jack just fine. But, when I try to connect a Layer 2 switch (a trendnet TPE-S44 v3 with 4 PoE ports), everything from the switch down does not get network traffic.
I can connect the L2 switch to my wifi router and get the traffic to work there, but now everything gets double NATted to the outside world and that's exactly what I am trying to avoid.
Two questions:
1. Is this theoretically possible? I would think so, but maybe my brain is missing something obvious...
2. One of the options in the CM1100 is to set up Port Aggregation - that's bonding two ports together for double throughput, right? I wouldn't want to do that if I am trying to create 2 separate networks (wired vs WiFi) right?
Any help appreciated 🙂
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
On the second ethernet port, I am able to pull a private IP to my laptop, and can connect to the internet through the jack just fine. But, when I try to connect a Layer 2 switch (a trendnet TPE-S44 v3 with 4 PoE ports), everything from the switch down does not get network traffic. This won't work. Need a router here.
Two questions:
Yes, if the ISP supports having two WAN assigned IP addresses from the ISP to the one modem. Some ISPs don't allow this or support this for home users. You need a wifi router connected with the CM1100 to service ANY and ALL wireless and wired devices thru the modem. The modem does NOT have a router built in. Yes, I've had two routers connected to my CM series modems when I had them online. My ISP supports me having more then one WAN IP address when I use these modems.
2. One of the options in the CM1100 is to set up Port Aggregation - that's bonding two ports together for double throughput, right? I wouldn't want to do that if I am trying to create 2 separate networks (wired vs WiFi) right? Correct, LAG enables both ports to 1 WAN IP address so when LAG is enabled, you only get 1 WAN IP address across both ports.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Two questions:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk CM1100
Well, assign a stupid label on me - I should have considered that the switch doesn't route traffic. Thanks for the reminder 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
