Orbi WiFi 7 RBE973
Reply
Nighthawk X4S Slow Download Speeds
DaveMoreland
My X4S AC3200 cable modem occasionally will have the download speeds slow to 1 mbps or less while the uploads remain normal at 35-40 mbps.  I am paying for 400 mbps download speeds.  You can restore factory settings on the modem and it will fix the problem but it will occur again at random times.  Usually stays fixed for a couple of months or more before you have to restore the factory settings again.  Anyone else having this problem?
Message 1 of 17
Accepted Solutions
Guru
Re: Nighthawk X4S Slow Download Speeds
Ok hoping you or ISP and get it working better...
Message 10 of 17
All Replies
Guru
What model series modem do you have? AC3200 is a combined wireless speed, not a modem model.
Message 2 of 17
DaveMoreland
It's a C7800v2
Message 3 of 17
Guru
Be sure your using a good quality LAN cable between the modem and PC. CAT6 is recommended.
What is the connection rate seen on the PCs ethernet adapter. Should see 1000Mpbs
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=2431
Message 4 of 17
DaveMoreland
1. Yes, we are using CAT6.
2. Connection rate is 1000 Mbps
3.
Apply             Cancel
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
<tabindex=-1>Startup Procedure</tabindex=-1>
ProcedureStatusComment
Acquire Downstream Channel561000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityENABLEDBPI+
IP Provisioning ModeHonor MDDAPM
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectabables
1LockedQAM2561561000000 Hz-9.3 dBmV35.9 dB10
2LockedQAM2562567000000 Hz-9.8 dBmV35.7 dB20
3LockedQAM2563573000000 Hz-9.4 dBmV36.0 dB60
4LockedQAM2564579000000 Hz-10.3 dBmV35.5 dB100
5LockedQAM2565585000000 Hz-10.1 dBmV35.6 dB50
6LockedQAM2566591000000 Hz-10.4 dBmV35.7 dB50
7LockedQAM2567597000000 Hz-10.6 dBmV35.5 dB70
8LockedQAM2568603000000 Hz-10.8 dBmV35.2 dB180
9LockedQAM2569609000000 Hz-10.9 dBmV35.3 dB50
10LockedQAM25610615000000 Hz-11.3 dBmV35.0 dB40
11LockedQAM25611621000000 Hz-12.1 dBmV34.7 dB130
12LockedQAM25612627000000 Hz-12.8 dBmV34.5 dB160
13LockedQAM25613633000000 Hz-12.4 dBmV34.7 dB160
14LockedQAM25614639000000 Hz-11.9 dBmV34.8 dB200
15LockedQAM25615645000000 Hz-11.0 dBmV35.1 dB50
16LockedQAM25616651000000 Hz-11.0 dBmV35.0 dB70
17LockedQAM25617657000000 Hz-10.7 dBmV35.1 dB50
18LockedQAM25618663000000 Hz-10.6 dBmV35.2 dB50
19LockedQAM25619669000000 Hz-10.2 dBmV35.2 dB70
20LockedQAM25620675000000 Hz-10.9 dBmV35.0 dB30
21LockedQAM25621681000000 Hz-10.0 dBmV35.3 dB30
22LockedQAM25622687000000 Hz-10.7 dBmV35.2 dB60
23LockedQAM25623693000000 Hz-10.1 dBmV35.3 dB40
24LockedQAM25624699000000 Hz-10.5 dBmV35.3 dB20
25LockedQAM25625705000000 Hz-9.7 dBmV35.3 dB2169762905
26LockedQAM25626711000000 Hz-10.2 dBmV35.2 dB2612867909
27LockedQAM25627717000000 Hz-9.4 dBmV35.4 dB10
28LockedQAM25628723000000 Hz-10.2 dBmV35.1 dB30
29LockedQAM25629729000000 Hz-9.7 dBmV35.2 dB20
30LockedQAM25630735000000 Hz-10.1 dBmV35.2 dB10
31LockedQAM25631741000000 Hz-9.5 dBmV35.2 dB00
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA192560 Ksym/sec25000000 Hz50.5 dBmV
2LockedATDMA175120 Ksym/sec37500000 Hz50.8 dBmV
3LockedATDMA185120 Ksym/sec30700000 Hz50.8 dBmV
4LockedATDMA202560 Ksym/sec21400000 Hz50.0 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
ChannelChannel IDIndicatorSubcarrier Zero FrequencyActive Subcarrier Number RangeTotal CodewordsUncorrectable Codewords
133Primary677600000 Hz1588 ~ 25072498646170
20Other0 Hz0 ~ 000
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
ChannelUpstreamIsMutedRanging StatusSubcarrier Zero FrequencyActive Subcarrier Number RangeSymbols Per FrameTx Power
1 Other0 Hz0 ~ 000 dBmV
2 Other0 Hz0 ~ 000 dBmV
Current System Time: Tue, Aug 16, 2022 12:14:20
4.ISP has been out and has replaced coax beginning at the pole outside all the way into the house. (We had the inside coax replaced)
5. Signal quality has been checked and ISP provisioned modem correctly.
6. No splitters between modem and ISP service box.
7. All interior coax was replaced and new coax professionally installed.
8.  Power off procedure has been followed.
Message 5 of 17
Guru
You power levels are too LOW:
Also you have correct and un-correctables that should be zeros.
Check your coax fittings and ensure they are snug.
Have the ISP check for this and the power levels. The ISP will need to work with you on this.
Be sure to use Ooklas installable speed test app to test speeds with a wired PC. Ensure other devices are disconnected or not using bandwidth before testing.
Message 6 of 17
DaveMoreland
Thank you for this info!  We have Suddenlink so good luck with their customer service.
I'll do some troubleshooting...does low power level generally indicate signal loss at a splitter or cable connection?
I'll check and make sure there's not a splitter somewhere in the attic that I'm missing.
Excuse my ignorance but what would cause the "correct and un-correctables" issues and what should I be looking for to correct that.
And another stupid question.  Does a signal amplifier that would be used on a tv antenna signal help boost a cable internet signal and would there be any advantage to installing an amplifier in this case? Or would that even be possible?🤔
I do use Ookla Speedtest on a wired PC.  When it has an issue the download speeds are 1mbps or less and the uploads are in the 40 mbps range.  When things are working I generally get anywhere between 90 and 250 mbps downloads with the uploads staying about the same.  This speed is restored when we restore the factory settings on the router.
Thanks again for all your help!
Dave
Message 7 of 17
Guru
Yes can be due to a splitter or cable connection.
Loose cable jacks or not screwed in all the way, kinked cabling or bad cabling or splitters can cause correct and un-correctables. The modems is trying to correct data flow where i can and can not. This is where this gets reported.
I would ask the ISP first if a amp maybe needed or should be used. Not sure what kind of amp that could be used if one is needed.
Message 8 of 17
DaveMoreland
Thanks for the great advise!  I will check for coax connection issues.
This is an essential connection since this is a computer that is used for a work at home job.  We are presently paying for a second internet provider (T-Mobile 5G) just because this one has so many issues! Unfortunately T-Mobile is not perfect either so at this time it makes sense to keep both.
Message 9 of 17
Guru
Message 10 of 17
Guru
And if ISP doesn't do anything, you could short term rent one of there modems to see if the problem continues, if so, this can be additional help in proving the ISP needs to fix this.
Message 11 of 17
DaveMoreland
Good idea. I used to have one of their modems but it got zapped in an electrical storm which prompted me to buy my own.
I never had this problem with the cable modem from Suddenlink so that's why I think there's some issue with this particular model of modem.
Message 12 of 17
Guru
Also I would place a laptop cooler under this modem as well. Helps keep the unit cooler and helps with electronics longevity as well.
Message 13 of 17
DaveMoreland
Thanks!  I will look into that.
Message 14 of 17
Guru
Message 15 of 17
DaveMoreland
Message 16 of 17
Guru
Message 17 of 17
Top Contributors
Discussion stats
  • 16 replies
  • 3071 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
