ccjohnson99's avatar
ccjohnson99
Follower
Mar 16, 2018
Outside wifi interference
My internet constantly drops due to interference from others on the same channel. I have tried every channel and the same results happens each time. It also happens on 2G and 5G.  I use Netgear Genie on my laptop to see why I’ve lost signal at that moment and each time it appears that someone else is on that channel. Help!
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    I would stick to the channel that is clear while other networks will keep jumping around and will sometimes jump to the one you are using.
    DarrenM
