kgrochowik's avatar
kgrochowik
Port Forwarding Problems - C7000-100NAS
I have a C7000-100NAS modem/router combo. I have port forwarded (not on this unit) several hundred times on various models/makes of routers and until now I cannot figure this thing out. I am trying to forward a few ports (4369, 8100) and everytime I check a port tool they show closed. I have the most recent firmware, have performed a reboot and factory reset/default, unchecked ipv4 firewall disable, messed with upnp, usb, and other settings and nothing seems to work. I can forward one port if i enter an ip of one of the devices into the DMZ server field but that only works for one IP. Help Please!?!?!?!?
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    did you try checking the ports via OUTSIDE connection? (not from home).
    such as LTE or other network.
  • I am having the exact same problem. The modem/router did accept UPNP from my computer but then dropped it for no reason. Now, UPNP doesn't work nor does port forwarding.
    • 438hp's avatar
      438hp
      Not sure why, but port forwarding is working now.
