barnes3001
Apr 03, 2023Follower
Resetting admin password
I know the steps to reset my Netgear Nighthawk CAX30 router admin password, but it doesn't address the effects of resetting my admin password.
By effects, I mean do I have to setup everything all over again, such as SSID and Password and any tweaks that may have been done along the way?
1 Reply
If you change the admin log in PW using the WEB UI and PW change feature, no, you won't have to re-setup anything else.
If you factory reset the modem by pressing the reset button in back, then yes you would have to setup the modem and configure it again.
