dem48306's avatar
dem48306
Follower
Sep 23, 2023
Router IP Address
Hi,
I have a basic question. Is there anyway to see the IP addresses of the UniFi switch I have connected to my CM2000?
I can log into the modem interface but can't find any info on connected devices.
Note, I can see the address of the device thru the UniFi controller s/w, but it is just set to the default 192.168.1.20 .  I think it should be pulling a new IP thru the CM2000 ? but may be wrong (not an IT guy, just a simple home network)
waiting on Unifi support on this also, but thought I would see if there was anything I could do/check from Netgear side
1 Reply
  • FURRYe38's avatar
    The CM series modems are not routers, just modems only.
    You'll need to contact the mfr for help, support and information regarding there switch product.
    Good Luck.
