renoryan007's avatar
renoryan007
Follower
Aug 19, 2022
Routs lights are all flashing white
My Nighthawk X4S AC3200 (C7800) is flashing all white lights.  I unplugged the unit from the outlet and plug it back in and the white lights continue to flash.  Any idea what is happening?  Is my router toast?
1 Reply
  • FURRYe38's avatar
    Unplug the ISP coax line and all wired devices from the from the modem, then press the reset button for 10 seconds then release. Does this change the behavior?
    Check the user manual to see what the LED status means for what your seeing.
    Can you access the modems web page at 192.168.100.1 at all with a wired PC after the reset is performed?
