glenaw
Oct 15, 2015Follower
Turn a Wireless Cable Modem into a access point
I own a Wireless Cable Gateway cg3000d. Can I turn this device into a access point?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello glenaw
This modem does not have a Access point setting but you can try to make it a access point by going into the LAN ip settings and setting the DHCP server to No and then try connecting int to your main router. Not 100% sure this will work since its not ment to be a access point.
DarrenM
