- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to Set Static ip, DHCP options, or anything in the web interface
- Mark as New
- Bookmark
- Subscribe
- Permalink
To whom this may concern,
At this time I am continuing to use basic functionality of the device I have purchased. I would have assumed this device would have been competent enough for the higher pricepoint to accomidate DHCP options, Setting a Default LAN subnet customization or even having management features that functioned through the web UI.
Clearly I am mistaken, Is anyone else having these problems, and or have a solution or work around to better manage this device ? (AX80)
--- Edit : After more research and digging through the logs, Along with discovering Telnet is responding on the WAN interface for whatever god unknowing reason. I am returning this product and avoiding all netgear devices like the black plauge in the future after dumping the debug.htm logs and discovering the chineese successfully authenticating to the device before I have even had a chance to set it up.
Netgear get your S*** together and test a product before you decide to sell it to people.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to Set Static ip, DHCP options, or anything in the web interface
For the RAX80 router, please post about this in the correct RAX series forum:
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Firmware version? Connected to what?
> [...] Is anyone else having these problems, [...]
What, exactly, are "these problems"? "Unable" is not a useful
problem description. It does not say what you did. It does not say
what happened when you did it. As usual, showing actual actions
(commands) with their actual results (error messages, LED indicators,
...) can be more helpful than vague descriptions or interpretations.
Which "DHCP options" would you like to control? (Netgear firmware
for its consumer-grade routers tends to offer very little in this
neighborhood.)
> [...] discovering Telnet is responding on the WAN interface [...]
How, exactly, did you discover that? If you're testing from a device
on the router's LAN, using the router's WAN/Internet IP address, then
NAT loopback could cause misleading results.
> [...] after dumping the debug.htm logs and discovering [...]
Thanks for including some actual evidence.
> [...] I am returning this product [...]
Perhaps there's no point, then, in providing a useful problem
description.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
