Beretta325's avatar
Beretta325
Xfinity AX6000 Gigabyte internet
I recently bought the AX6000 hooked it up update to latest firmware and ran a speed test. Was only getting 340-400 mbps out of the 1200 mbps. Also did the speed test on the Netgear app and only getting 450 mbps. Any suggestions?
  • FURRYe38's avatar
    Is this wired speed tests with a wired PC?
    You should see 1.2Gb with a wired PC on the MultiGig port in back with a multigig ethernet adatper supported PC.
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
  • Cable Diagnostic
    Status: Good
    Action: Your setup looks fine.
    Internet Access: Good
    Downstream Status: Good
    Downstream Power Level: Good
    Downstream SNR: Good
    Upstream Status: Good
    Upstream Power Level: Good
    Current time: Mon May 13 07:23:09 2024
    Startup Procedure
    Acquire Downstream Channel: 525 MHz Locked
    Connectivity State: OK Operational
    Boot State: OK Operational
    Security: Enabled BPI+
    Downstream Bonded Channels
    Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
    1 Locked 256 QAM 29 525000000 Hz 3.1 dBmV 40.5 dB 0 0
    2 Locked 256 QAM 1 345000000 Hz 2.6 dBmV 40.9 dB 0 0
    3 Locked 256 QAM 2 351000000 Hz 2.6 dBmV 41 dB 0 0
    4 Locked 256 QAM 3 363000000 Hz 2.1 dBmV 40.8 dB 0 0
    5 Locked 256 QAM 4 369000000 Hz 2.4 dBmV 40.8 dB 0 0
    6 Locked 256 QAM 5 375000000 Hz 2.6 dBmV 40.8 dB 0 0
    7 Locked 256 QAM 6 381000000 Hz 3.1 dBmV 40.9 dB 0 0
    8 Locked 256 QAM 7 387000000 Hz 3.2 dBmV 40.9 dB 0 0
    9 Locked 256 QAM 8 393000000 Hz 3.4 dBmV 40.9 dB 0 0
    10 Locked 256 QAM 9 399000000 Hz 3.6 dBmV 40.9 dB 0 0
    11 Locked 256 QAM 10 405000000 Hz 3.7 dBmV 40.9 dB 0 0
    12 Locked 256 QAM 11 411000000 Hz 4 dBmV 41 dB 0 0
    13 Locked 256 QAM 12 417000000 Hz 4 dBmV 41 dB 0 0
    14 Locked 256 QAM 13 423000000 Hz 4.1 dBmV 41 dB 0 0
    15 Locked 256 QAM 14 429000000 Hz 4.3 dBmV 41.1 dB 0 0
    16 Locked 256 QAM 15 435000000 Hz 4.3 dBmV 41.1 dB 0 0
    17 Locked 256 QAM 16 441000000 Hz 4.2 dBmV 41.1 dB 0 0
    18 Locked 256 QAM 17 447000000 Hz 4.2 dBmV 41.1 dB 0 0
    19 Locked 256 QAM 18 453000000 Hz 4.2 dBmV 41 dB 0 0
    20 Locked 256 QAM 19 459000000 Hz 4.2 dBmV 41 dB 0 0
    21 Locked 256 QAM 20 465000000 Hz 4.2 dBmV 41 dB 0 0
    22 Locked 256 QAM 21 471000000 Hz 4.2 dBmV 41 dB 0 0
    23 Locked 256 QAM 22 477000000 Hz 4.1 dBmV 40.9 dB 0 0
    24 Locked 256 QAM 23 483000000 Hz 4.2 dBmV 41 dB 0 0
    25 Locked 256 QAM 24 489000000 Hz 4 dBmV 40.9 dB 0 0
    26 Locked 256 QAM 25 495000000 Hz 4 dBmV 40.8 dB 0 0
    27 Locked 256 QAM 26 507000000 Hz 3.8 dBmV 40.7 dB 0 0
    28 Locked 256 QAM 27 513000000 Hz 3.5 dBmV 40.6 dB 0 0
    29 Locked 256 QAM 28 519000000 Hz 3.3 dBmV 40.6 dB 0 0
    30 Locked 256 QAM 30 531000000 Hz 2.7 dBmV 40.3 dB 0 0
    31 Locked 256 QAM 31 537000000 Hz 2.7 dBmV 40.3 dB 0 0
    32 Locked 256 QAM 32 543000000 Hz 2.4 dBmV 40.2 dB 0 0
    Upstream Bonded Channels
    Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
    1 Locked ATDMA 3 5120 Ksym/sec 22800000 Hz 40.5 dBmV
    2 Locked ATDMA 2 5120 Ksym/sec 16400000 Hz 41.0 dBmV
    3 Locked ATDMA 4 5120 Ksym/sec 29200000 Hz 40.5 dBmV
    4 Locked ATDMA 5 5120 Ksym/sec 35600000 Hz 40.0 dBmV
    5 Locked ATDMA 6 2560 Ksym/sec 40400000 Hz 42.5 dBmV
    6 Not Locked Unknown 0 0 0 0.0
    7 Not Locked Unknown 0 0 0 0.0
    8 Not Locked Unknown 0 0 0 0.0
    Downstream OFDM Channels
    Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
    1 Locked 0 ,1 ,2 ,3 159 564000000 Hz 3.28 dBmV 40.5 dB 1126 ~ 2969 1258904857 95968797 0
    2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0
    Upstream OFDMA Channels
    1 Not Locked 0 0 0 Hz 0 dBmV
    Event Log
    Time Priority Description
    Sun May 12 21:21:02 2024 Warning Dynamic Range Window violation
    Sun May 12 21:21:02 2024 Warning RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=70:1f:53:99:41:cb;CM-QOS=1.1;CM-VER=3.1;
    Sun May 12 21:20:57 2024 Notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=70:1f:53:99:41:cb;CM-QOS=1.1;CM-VER=3.1;
    Sun May 12 21:20:37 2024 Notice TLV-11 - unrecognized OID;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=70:1f:53:99:41:cb;CM-QOS=1.1;CM-VER=3.1;
    Thu Jan 1 00:00:55 1970 Notice Honoring MDD; IP provisioning mode = IPv6
    Thu Jan 1 00:00:43 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
    Sat May 11 00:06:45 2024 Critical Resetting the cable modem due to docsDevResetNow
    Thu Jan 1 00:03:07 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=70:1f:53:99:41:cb;CM-QOS=1.1;CM-VER=3.1;
    Thu Jan 1 00:02:39 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
    Thu Jan 1 00:00:55 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
    Sun May 12 21:21:02 2024Warning (5)Dynamic Range Window violation
    Sun May 12 21:21:02 2024Warning (5)RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=70:1f:53:99:41:cb;CM-QOS=1.1;CM-VER=3.1;
    Sun May 12 21:20:57 2024Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=70:1f:53:99:41:cb;CM-QOS=1.1;CM-VER=3.1;
    Sun May 12 21:20:37 2024Notice (6)TLV-11 - unrecognized OID;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=70:1f:53:99:41:cb;CM-QOS=1.1;CM-VER=3.1;
    Thu Jan 1 00:00:55 1970Notice (6)Honoring MDD; IP provisioning mode = IPv6
    Thu Jan 1 00:00:43 1970Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
    Sat May 11 00:06:45 2024Critical (3)Resetting the cable modem due to docsDevResetNow
    Thu Jan 1 00:03:07 1970Critical (3)No Ranging Response received - T3 time-out;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=70:1f:53:99:41:cb;CM-QOS=1.1;CM-VER=3.1;
    Thu Jan 1 00:02:39 1970Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
    Thu Jan 1 00:00:55 1970Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:8d:8a:83;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
