Orbi WiFi 7 RBE973
Reply
cax30 - dhcp reservation 0.0.0.0
bozojoe
Guide
Im trying to set a DHCP reservation for a MAC from a dell PC.   However no matter what value I input for the IP the user interface resets the IP to 0.0.0.0 after hitting the "add" button.
Message 1 of 8
Accepted Solutions
bozojoe
Guide
Re: cax30 - dhcp reservation 0.0.0.0
Found the solution.
the IP must be in the DHCP range.    my range happened to start at x.x.x.100 to x.x.x.253.
I wanted a reservation of x.x.x.50.     that didnt work
however
inputing x.x.x.150   DID work.
Message 2 of 8
All Replies
bozojoe
Guide
Found the solution.
however
Message 2 of 8
Guru
Yes to reserve and IP address, it must be in the DHCP IP address range. Anything outside of the IP address pool range can be set for a STATIC IP address which is set ON devices, not the router.
Message 3 of 8
bozojoe
Guide
Your right, I kinda forgot all my networking skills this week.    Too bad the UI doesnt remind the user.
Message 4 of 8
Guru
Smiley Wink
Ya, would be nice...
Glad you got it working.
Message 5 of 8
antinode
Guru
> Yes to reserve [an] IP address, it must be in the DHCP IP address
   Why?  Around here (D7000[v1], V1.0.1.78_1.0.1), that would be
considered a firmware bug.
   My DHCP pool range is ".224" - ".239".  I have 23 address
reservations, all of which are outside the pool.  I also have some
devices with static (ex-pool) addresses.
   Obviously, there's no compelling reason for such a restriction.
> Found the solution.
   Not what I'd call a "solution".
> [...] Too bad the UI doesnt remind the user.
   I'd say, "Too bad the (unspecified) firmware's defective."
Message 6 of 8
schumaku
Guru
Correct, I can't agree more: There is no reason for such a limitation. When I have it right, I complained about the limitation on the D7000 and some other subsequent Dxxxx Beta tests ... and it was changed accordingly on select products. Why ever, it never made it to the standard specs.
In my router and security appliance world this is the way most units work - we can add any address, regardless if inside or outside of the generic "free" DHCP pool, as a reserved MAC<->IP pair.
It's a question of specification, standardisation, and testing.
It does not remind the user because the default DHCP poo is wide open (.2 ... .254 when I have it right) on Netgear routers - so the majority of users never hit this limitation.
I would expect the UI would allow enabling/disabling for IP<->MAC pairs already known (from the connected devices table) and adding reservation, regardess if these addresses are in the DHCP pool or not.
Correct UI behaviour would be to inform the user if the IP is outside of the pool, but allow continuing.
Needless to say, if the design does not allow IP addresses outside of the configured IP pool range, the user must be informed.
I'm fully with @bozojoe here.
@antinode  All this was discussed and complained many times. Netgear's consumer router product management and development lost the contact to the reality out here in the market years ago already. Specs change randomly, UI behaviour does change randomly, there is no standardisation on product features (and even less on testing). Products are run under marketing numbers, generic features (outside of the latest and greatest WiFi and Mesh tech) as well as product continuity and standards don't count anymore.
Message 7 of 8
antinode
Guru
> Correct UI behaviour would be to inform the user [...]
   I'd say that the correct behavior would be to do what the user
requested, and keep quiet about it.  The way my D7000 does (and has done
for years).
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2651 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi 770 Series
