fsavala
May 03, 2016Aspirant
ethernet showing not connected on pc on my N600
For some reason out of no where my pc is showing that my ethernet port is not connected when it is. I have reset it, changed cables, tried to hook my second pc up, switched ports on back. Same results on both pcs. Weird thing is, is my xbox is wired and even switching ports and using the other cable and no problems with connectivity. Please help!
Is the port, perhaps, disabled on your PC?
- fsavalaAspirant
I dont believe so. In fact, no settings were ever changed on either pc I hooked it up to. Honestly I dont remember how to even change that. Whats weird is that my xbox works fine on either connection and both ethernet cables. Literally just worked one day then the next it said the ethernet cable was disconnected.
Are you running Windows? If so, you'll probably want to pull up the Device Manager and make sure the Ethernet card is listed as a Network Adapter. Did you try using a different port on the router?
