damianpv's avatar
damianpv
Follower
Oct 03, 2020
no turning on, network ligths flashing
router led aren't turning on, only network ligths in the back are flashing.
when a turn off the swith the power led turn red for a second.
damaged probably by a lightning.
any suggestion on how to fix it ?
1 Reply
  • FURRYe38's avatar
    Try a different power supply.
    Factory reset.
    If nothing fixes this, modem needs to be replaced.
