morephious's avatar
morephious
slow/terrible internet on N300 (c3000-100nas) docsis3 with android streaming device.
I have comcast blast 150Mbs download and 10Mbs Upload speed.  When I connect a PC directly to port 1 speed test gives me 175Mbps download and 11 Mbps upload.  On my Android Streaming device I get 21Mbps down and 5 Mbps upload.  Rebooted Router etc.
Any suggestions why I get such slow speeds?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello morephious
    What android device are you having a slow down on and is connected via lan or wifi? Have you tried any other device to test speeds on other than your PC? Hope to hear your feedback.
    DarrenM
    • morephious's avatar
      morephious
      Lan and wifi.  I am using a Mediacube.  The website is mediacube.co
      • DarrenM's avatar
        DarrenM
        Morephious
        I cant find much information on this product but I do see it only has a 10/100 ethernet port on it so it cant go over 100mbs on Lan but it should be capable of your 150mbs on wifi. How are you testing the speed on the mediacube do they have a speed test built into the device or are you using a website threw a browser? The other question I have is are you having any buffering issues with it being at 21mbps becauses alot of streaming services should work just fine at this speed.
        DarrenM
