- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
why my hand made ethernet cable produce blinking orange line on modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
i use ethernet cat6, T568B wiring method.
what has gone wrong?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: why my hand made ethernet cable produce blinking orange line on modem
Hi huynhducloi,
Welcome to NETGEAR Community!
Thank you for reaching out. May we know what is the model of your Cable modem? Did you test another ethernet cable?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your handwired wire has a not completed pair it could be connecting at 10/100mbps connection and not gigabit.
This is what I see most often.
Try a good quality cat 6 cable and check the connection. If thats fine, then you'll need to check your cable ends. (usually where its bad).
I've also seen people strip the protective cover off prior to crimping and nick the cable causing bad connections. It can be a little frustrating when you first start handwiring cables.
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi, thanks a lot for following -up.
The interesting thing is that i have tested my hand-made ethernet cable with RJ45 tester (etc. cable tester), and all the lights from 1 to 8 is light up correctly.
I don't know if netgear needs special wiring instruction. I tried the netgear provided ethernet cable and it lights up green as expected, but i just dont know why my hand-made not working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you test different ethernet cable? CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes, i had cat 6. if this hand-made cable works with other modem, it means that netgear modem has some very special requirement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you did try a pre-made/Mfrs cable with this modem to see if it worked and had same issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes, the premade came with the box, work fine. so i am curious on what is the difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What CAT version is the one in the box?
What kind of cable are you using? UTP? Stranded pair?
Possible you might have something wired differenctly on your hand build from Mfr'd.
- Mark as New
- Bookmark
- Subscribe
- Permalink
could be not crimped all the way. Just enough to pass a current but not enough for data. I've seen that.
I'd try redoing your ends
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem is not with the way i do my ethernet. I have tested them on different modems, work fine.
Why out-of-box CAT 5e works, with green light, speed 500Mbps.
and my hand-made CAT 6, creates orange blinking light, speed <100Mbps.
If i try to hand-made CAT 5e and it works, , Something is wrong with Netgear modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, bought ones work fine.
Your hand crimped ones don't.
But your hand crimped ones work with other devices.
Maybe the netgear needs a better quality of end crimp than other devices so it has better connections/throughput/less drops?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
