maniont58
Jun 11, 2020Aspirant
AC1750/r6400v2 running V1.0.4.78_10.0.55. how to disable wireless isolation
My issue is the following. My laptop is on 5GHz, my new printer only connects to 2.4GHz.
My laptop cannot see the printer.
I believe that if I disable wireless isolation, my laptop will be able to see my printer.
BUT, I cannot find the setting to disable wireless isolation.
Is this possible on my model, and if so, how do I do it?
Thanks,
Tom
1 Reply
Please post about this in the NG router forum for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you.
maniont58 wrote:My issue is the following. My laptop is on 5GHz, my new printer only connects to 2.4GHz.
Thanks,
Tom
