BartE's avatar
BartE
Follower
Mar 11, 2018
Ausu tablet will not connect
A tablet that does not connect.
I recently purchased a Netgear AC1750-C6300. The WiFi works on 2 desk tops, 2 smart phones, one printer and one lap top. I also have a Asus tablet model T200TA-C1-BL running Windows 8.1, with a Broadcom 802.11abgn wireless adapter running on driver 5.93.105.5 that does not connect. I look at the username profile in “netsh” and compare with a functioning computer and they are th same. The Netgear history shows ‘[WLAN access rejected: incorrect security] from MAC: 6c:fa:a7:3a:00:16.”
Any suggestions
1 Reply
  • michaelkenward's avatar
    michaelkenward
    What happens when you try to connect? Any pop up windows? Password rejected? Windows errors?
    Many "my device won't connect" issues are down to the device rather than the wifi sources.
