Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C3000 Speed Capped at 50 MBPS
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-04
05:54 PM
2020-03-04
05:54 PM
I have a C3000 Cable Router + Modem. i see in its settings that it supports 2.4 GHZ, I opted for a 300 MBPS Cable internet connection, but I never get more than 20 MPBS speed on any speed test. When i speak with the Cable Operator , they say i should get at least 250 MBPS speed as they see on their side.
Is this something to do wtih settings or it is just that the Router does not support more than 20 MBPS speed?
Model: C3000|N300 Cable Gateway Docsis 3.0
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-05
08:12 PM
2020-03-05
08:12 PM
Re: C3000 Speed Capped at 50 MBPS
You probably wont see the 300Mbps speeds if you're only testing it wirelessly. Your modem/router will easily push 300Mbps+ directly from the Ethernet ports (backside), but not on the 2.4Ghz wireless band -it's a congested and watered-down air space. To reach higher speeds wirelessly, you may have more success with dual band routers that are either wifi5 or wifi6 standard because you'll have the addition of the 5Ghz wireless band.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-06
08:01 AM
2020-03-06
08:01 AM
What are you getting with a wired PC connection?
Message 3 of 3
Announcements
