tropicsky
Oct 16, 2016Aspirant
C6300 guest login - how to set up?
I need to set up a guest login for a vacation rental unit, I'm not finding anything. Hope someone cen help me, thank you!
Page 60 in the manual.
- tropicskyAspirant
Thank you! Now my problem is the IP address is different. Will I create problems if I reset the router?
- What do you mean your IP address is different?
You can certainly reset your router. Either back up your settings, write them down or take screenshots.- tropicskyAspirant
When I went to the routerlogin.net website it says
By default, your NETGEAR home router IP address should be assigned as either 192.168.1.1 or 192.168.0.1.
My IP address is 10.0.1.30. The routerlogin website says I'm not connected to the router's Wifi network.
Thanks for your help
Use the router's address to log in. This article shows you how to determine the router's address.
