E-Rock's avatar
E-Rock
C7000 enable SNMP/sFlow/Other Network Monitoring
I'm running a C7000-100NAS, hardware version 1.05 and firmware version V1.01.29.
I'm trying to figure out how to enable some sort of networking monitoring be it SNMP, sFlow, NetFlow, or some other type of network monitoring. The goal is catch errors, capture number of dropped packets, and monitor bandwidth usage of the device. If anyone has a solution out there, I'd greatly appreciate it.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    none of those will work for you.
    SNMP is fully supported by it ONLY works from ISP side. ISP and NTGR blocks it from LAN side.
    you may want to look at scripting stuff via HTML/HTTP GUI.
    • E-Rock's avatar
      E-Rock
      Is there an HTTP API available that I can reference to build a script?
      • vkdelta's avatar
        vkdelta
        no. nothing is available.
        Few folks use some curl scripts to check I have seen previously in other forums.
