Dricky's avatar
Dricky
C7000
How can I setup this router for optimal gaming performance?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Dricky
    If you are using a console you may want to look into port forwarding for your system.
    DarrenM
    • Dricky's avatar
      Dricky
      Hey Darren,
      i am using a console and I did port forward it because certain games like call of duty for example won't give me an open NAT if I don't do it. However, the thing is whenever I do that and then I play another game online like NBA2k17, the lag is horrible. Even getting to play with a friend is like impossible. I'm stuck always having to modify the settings which is a pain. I think I might just have to get a new internet setup.
      • DarrenM's avatar
        DarrenM
        Hello Dricky
        You may want to do some speed tests and packet loss tests to see if its the ISP causing the Lag.
        DarrenM
