Casualpear's avatar
Casualpear
Follower
Oct 01, 2017
CG3100D-2 connection issues when changing back to IPv4 Only.
Hi.
Lastnight I changed my NAT settings to Bridge mode to bypass some peer to peer gaming connection issues. Which ed worked out great etc.
But when changing the setting back to NAT IPv4 Only mode now nothing connects to the Internet even though the modem is showing green across the board.
Telstra has just palmed me off saying that there's an Internet connection. I've tried pretty much everything I can think off and with a lot of help from Google.
Everything from Restoring Factory settings to even trying a third party router.
I've completely ran out of options and really need to know why this is a problem..
Thanks.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You could bridge the modem again and use your other router connected to it see that works.
    DarrenM
