CarlH123's avatar
CarlH123
Follower
Oct 30, 2019
CM700 DHCP Configuration
Is it possible to configure DHCP on the CM700 cable modem?
I have a number of static assigned IP addresses for printers, access points, and servers.  I think the CM700 is assigning DHCP addresses that conflict with the static IP addresses.
I've tried logging into the modem at 192.168.100.1, but the configuration options don't include DHCP.
I've also tried www.routerlogin.net, both from a regular desktop and from a laptop plugged directly into the CM700, but I get an error message: "You may not be connected to your Router’s WiFi network. To access routerlogin.com, your device must be connected to your Router’s WiFi network. Check your current connection and try again." I tried a factory reset of the CM700 but it didn't make a difference.
My router is a Ubiquiti USG, not a netgear router.
I had thought that my router was doing the DHCP job, but then noticed today that DHCP was turned off on the router.  I turned it on, and set the available IP pool to 192.168.1.101 - 192.168.1.254.  After I did that, all 3 of my wireless access points (which have static IP addresses) went down.
I turned off DHCP on my router, but everything on the wireless side is still non-functional.  I would like to turn off DHCP on the cable modem, or reserve a range of IP addresses for my statically assigned equipment, but I haven't found a way to do that.
Any help would be much appreciated.
1 Reply
  • > Is it possible to configure DHCP on the CM700 cable modem?
       No.  Typically, DHCP is a router function, not a modem function.
    > I have a number of static assigned IP addresses for printers and
    > access points. [...]
       Where "static" means that you configured the address on the device
    itself?  What are these static addresses?
    > [...] I think the CM700 is assigning DHCP addresses on that conflict
    > with the static IP addresses. [...]
       I doubt that the CM700 is assigning anything related to DHCP, because
    it's only a modem, and lacks a DHCP server.
       I can believe/explain that. (No DHCP server there.)
    > My router is a Ubiquiti USG.
       That would explain why any (Netgear) "routerlogin" name would not
    work with it as it would with a Netgear router.
    > I had thought that my router was doing the DHCP job, [...]
       That would be usual.
    > [...] but then noticed today that DHCP was turned off on the router.
       Do you have devices which are using DCHP to get their IP parameters?
    If so, then that would suggest that you have a DHCP server running
    somewhere.  (And not on the CM700.)
    > [...] After I did that, all 3 of my wireless access points (which have
    > static IP addresses) went down. [...]
       Showing the actual addresses of these things would be more helpful
    than merely claiming that they exist.
    > [...] I would like to turn off DHCP on the cable modem, or reserve a
       If the CM700 had a DHCP server, then you might be able to fiddle with
    it, but it hasn't one.
       If DHCP was working when it was disabled on your router, then that
    would suggest that you have a DHCP server running on something else (but
    not on the CM700, which isn't even connected to the LAN side of your
    router).
       It sounds as if you have a rather complicated LAN, possibly a tangled
    one.  It might pay to start with some simple arrangement (modem, router,
    computer), and get that to work properly, and then start adding
    equipment and complexity.  (Until you break it.)
