jlclayton32's avatar
jlclayton32
Follower
May 12, 2017
Cm500
My CM500 stopped working out of nowhere, whenever I plug it in I have a blinking red power light and a blinking amber light on Ethernet. What can I do to fix this problem!!?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello jlclayton32
    The modem could be bricked you could try to factory reset the unit by holding the reset button for 10 seconds. If that does not work you may need to call support if the unit is still under warranty.
    DarrenM
