OTRrig19's avatar
OTRrig19
Follower
Jul 06, 2021
[DoS attack] ICMP Flood from ????
Hello my issue seems to be getting worse comcast has no idea.. ANY help would be great so confused as to why i am being DOS attacked.
Here is my cable connection just incase
Acquire Downstream Channel525000000 HzLockedConnectivity StateOkOperationalBoot StateOkOperationalSecurityEnabledBPI+IP Provisioning ModeHonor MDDhonorMdd(4)
annelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUnCorrectables
1LockedQAM 2561435000000 Hz-4.9 dBmV40.3 dB2526271470
2LockedQAM 2562441000000 Hz-4.4 dBmV40.3 dB2138217627
3LockedQAM 2563447000000 Hz-4.4 dBmV40.9 dB2238416155
4LockedQAM 2564453000000 Hz-4.2 dBmV40.3 dB2185910019
5LockedQAM 2565459000000 Hz-4.2 dBmV40.9 dB1831519869
6LockedQAM 2566465000000 Hz-4.0 dBmV40.3 dB1807430273
7LockedQAM 2567471000000 Hz-4.0 dBmV40.3 dB189908170
8LockedQAM 2568477000000 Hz-3.5 dBmV40.9 dB178837935
9LockedQAM 2569483000000 Hz-3.7 dBmV40.3 dB177948483
10LockedQAM 25610489000000 Hz-3.7 dBmV38.9 dB184458434
11LockedQAM 25611495000000 Hz-3.7 dBmV40.9 dB187179881
12LockedQAM 25612501000000 Hz-3.7 dBmV40.9 dB1826010807
13LockedQAM 25613507000000 Hz-3.7 dBmV40.3 dB1893810236
14LockedQAM 25614513000000 Hz-4.2 dBmV40.3 dB1906410086
15LockedQAM 25615519000000 Hz-4.0 dBmV40.3 dB1955410478
16LockedQAM 25616525000000 Hz-4.7 dBmV38.9 dB1893910766
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA45120 Ksym/sec17300000 Hz49.5 dBmV
2LockedATDMA35120 Ksym/sec23700000 Hz49.5 dBmV
3LockedATDMA25120 Ksym/sec30100000 Hz51.0 dBmV
4LockedATDMA15120 Ksym/sec36500000 Hz49.5 dBmV
Here this is throughout my logs multiple times ( i removed my actual IP )
[DoS attack] ICMP Flood from 169.51.141.1561Tuesday, 06 Jul 2021 17:06:51my ip169.51.141.156
[DoS attack] ICMP Flood from 172.104.241.1101Tuesday, 06 Jul 2021 17:00:23my ip172.104.241.110
No RepliesBe the first to reply
