Orbi WiFi 7 RBE973
Reply
Does CM500V support VDSL2?
DaisyM
I already have a CM500V modem,I wonder to know that is it support VDSL2?
Thanks
Model: CM500V|Cable Modem for Internet & Voice–DOCSIS 3.0
Message 1 of 4
Accepted Solutions
Guru
Re: Does CM500V support VDSL2?
C and CM series modes are only for Cable ISPs. No DSL support.
D and DM series are modems that support DSL.
Message 2 of 4
All Replies
Guru
Message 2 of 4
DaisyM
Thank you very much,I might need to buy a new modemSmiley LOL
Message 3 of 4
Guru
Check with your ISP before you buy to see what is supported first.
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 598 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
