Mattferg93's avatar
Mattferg93
Modem losing internet connection throughout day
Several times per day I am losing internet connection briefly before the modem reconnects. ISP (wowway) says everything is ok on their end, so it must be either the modem or the actual physical connection to the box outside. Firmware is up to date to my knowledge (V3.01.40) per the website for my ISP. They confirmed they are unable to push an update. It happened most recently at 3:17pm today, and I can post any relevent logs with that time if it will help. Thanks ahead of time!
  • FURRYe38's avatar
    Please post a copy and paste of the modems connection status page.
    Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Be sure to power OFF the modem for 1 minute them back ON.
    https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
    • chray754's avatar
      chray754
      Yes, Same issues starting around the same date June 10, 2021.  Running perfect for a year before then.  Xfinity firmware up to date V3.01.43 for Comcast.  ISP contacted and completed proper provisioning - all ok on their end, yet continued dropped service and Cable Staus downstream bonded channels drops to much less (e.g.11) bonded pairs (seen status below in working condition). Downstream Channel was ~475000000.  I did plenty of reboots.  Interesting that my logs were showing DoS attacks only from June 10 - onward.  Of course, Netgear community says all is normal with those.
      FINALLY< I did a "factory reboot" from the Admin home of the Genie.
      Current status from Cable Status menu is posted below and reflects all ok (for now).
      Hope this fixes it?  We'll see.
      C
      Frequency start Value
      This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
      Starting Frequency
      <tabindex=-1>Startup Procedure</tabindex=-1>
      ProcedureStatusComment
      Acquire Downstream Channel375000000 HzLocked
      Connectivity StateOKOperational
      Boot StateOKOperational
      SecurityENABLEDBPI+
      IP Provisioning ModeHonor MDDIPv6 only
      <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
      ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectabables
      1LockedQAM2561375000000 Hz7.6 dBmV42.0 dB00
      2LockedQAM2562381000000 Hz8.0 dBmV42.0 dB00
      3LockedQAM2563387000000 Hz8.0 dBmV41.9 dB00
      4LockedQAM2564393000000 Hz7.9 dBmV41.8 dB00
      5LockedQAM2565399000000 Hz8.0 dBmV41.8 dB00
      6LockedQAM2566405000000 Hz7.5 dBmV41.8 dB00
      7LockedQAM2567411000000 Hz7.2 dBmV41.7 dB00
      8LockedQAM2568417000000 Hz7.1 dBmV41.6 dB00
      9LockedQAM2569423000000 Hz6.5 dBmV41.4 dB00
      10LockedQAM25610435000000 Hz6.5 dBmV41.5 dB00
      11LockedQAM25611441000000 Hz6.2 dBmV41.3 dB00
      12LockedQAM25612447000000 Hz6.5 dBmV41.5 dB00
      13LockedQAM25613453000000 Hz6.3 dBmV41.3 dB00
      14LockedQAM25614459000000 Hz6.8 dBmV41.5 dB00
      15LockedQAM25615465000000 Hz7.0 dBmV41.5 dB00
      16LockedQAM25616471000000 Hz7.1 dBmV41.4 dB00
      17LockedQAM25617477000000 Hz7.5 dBmV41.6 dB00
      18LockedQAM25618483000000 Hz7.4 dBmV41.6 dB00
      19LockedQAM25619489000000 Hz7.9 dBmV41.6 dB00
      20LockedQAM25620495000000 Hz8.1 dBmV41.6 dB00
      21LockedQAM25621519000000 Hz8.8 dBmV39.5 dB00
      22LockedQAM25622525000000 Hz8.9 dBmV41.9 dB00
      23LockedQAM25623531000000 Hz8.8 dBmV41.8 dB00
      24LockedQAM25624537000000 Hz8.7 dBmV41.4 dB00
      25LockedQAM25625543000000 Hz8.6 dBmV41.8 dB00
      26LockedQAM25626549000000 Hz8.6 dBmV41.9 dB00
      27LockedQAM25627555000000 Hz8.5 dBmV41.5 dB00
      28LockedQAM25628561000000 Hz9.1 dBmV41.9 dB00
      29LockedQAM25629567000000 Hz8.8 dBmV40.9 dB00
      30LockedQAM25630573000000 Hz9.0 dBmV41.8 dB00
      31LockedQAM25631579000000 Hz9.0 dBmV41.8 dB00
      32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
      <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
      ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
      1LockedATDMA55120 Ksym/sec17300000 Hz40.0 dBmV
      2LockedATDMA65120 Ksym/sec23700000 Hz40.5 dBmV
      3LockedATDMA75120 Ksym/sec30100000 Hz40.8 dBmV
      4LockedATDMA85120 Ksym/sec36500000 Hz41.5 dBmV
      5Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      6Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      7Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      8Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
      ChannelChannel IDIndicatorSubcarrier Zero FrequencyActive Subcarrier Number RangeTotal CodewordsUncorrectable Codewords
      133Non-Primary605600000 Hz1108 ~ 298791390
      20Other0 Hz0 ~ 000
      <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
      ChannelUpstreamIsMutedRanging StatusSubcarrier Zero FrequencyActive Subcarrier Number RangeSymbols Per FrameTx Power
      1 Other0 Hz0 ~ 000 dBmV
      2 Other0 Hz0 ~ 000 dBmV
      Current System Time: Sat, Jun 12, 2021 18:15:47
    • Mattferg93's avatar
      Mattferg93
      Thanks for the reply. ISP says everything is good, just changed the coax cable as well. I'll have to look for splitters, in the meantime here's the connection page:
      Apply             Cancel
      Starting Frequency
      Acquire Downstream Channel657000000 HzLocked
      SecurityENABLEDBPI+
      IP Provisioning ModeHonor MDDIPv4 only
      1LockedQAM25626657000000 Hz-2.6 dBmV41.9 dB00
      2LockedQAM2561507000000 Hz-2.7 dBmV42.9 dB00
      3LockedQAM2562513000000 Hz-2.8 dBmV38.7 dB00
      4LockedQAM2563519000000 Hz-2.8 dBmV41.5 dB00
      5LockedQAM2564525000000 Hz-2.9 dBmV41.2 dB00
      6LockedQAM2565531000000 Hz-2.8 dBmV41.6 dB00
      7LockedQAM2566537000000 Hz-3.0 dBmV42.7 dB00
      8LockedQAM2567543000000 Hz-3.0 dBmV42.6 dB00
      9LockedQAM2568549000000 Hz-2.9 dBmV42.5 dB00
      10LockedQAM2569555000000 Hz-3.0 dBmV40.8 dB00
      11LockedQAM25610561000000 Hz-2.8 dBmV40.9 dB00
      12LockedQAM25611567000000 Hz-2.8 dBmV42.5 dB00
      13LockedQAM25612573000000 Hz-2.8 dBmV42.4 dB00
      14LockedQAM25613579000000 Hz-2.9 dBmV42.3 dB00
      15LockedQAM25614585000000 Hz-2.9 dBmV42.1 dB00
      16LockedQAM25615591000000 Hz-2.8 dBmV42.3 dB00
      17LockedQAM25616597000000 Hz-2.7 dBmV42.1 dB00
      18LockedQAM25617603000000 Hz-2.7 dBmV42.2 dB00
      19LockedQAM25618609000000 Hz-2.7 dBmV42.1 dB00
      20LockedQAM25619615000000 Hz-2.6 dBmV42.2 dB00
      21LockedQAM25620621000000 Hz-2.6 dBmV42.1 dB00
      22LockedQAM25621627000000 Hz-2.5 dBmV42.1 dB00
      23LockedQAM25622633000000 Hz-2.5 dBmV42.1 dB00
      24LockedQAM25623639000000 Hz-2.8 dBmV41.8 dB00
      25LockedQAM25624645000000 Hz-2.6 dBmV41.9 dB00
      26LockedQAM25625651000000 Hz-2.4 dBmV41.9 dB00
      27LockedQAM25627663000000 Hz-2.5 dBmV41.8 dB00
      28LockedQAM25628669000000 Hz-2.8 dBmV41.6 dB00
      29LockedQAM25630681000000 Hz-2.9 dBmV41.6 dB00
      30LockedQAM25631687000000 Hz-2.8 dBmV41.7 dB00
      31LockedQAM25632693000000 Hz-2.6 dBmV41.8 dB00
      1LockedATDMA85120 Ksym/sec16300000 Hz41.3 dBmV
      2LockedATDMA52560 Ksym/sec25500000 Hz41.5 dBmV
      3LockedATDMA65120 Ksym/sec30500000 Hz42.3 dBmV
      4LockedATDMA75120 Ksym/sec37000000 Hz43.8 dBmV
      129Non-Primary620600000 Hz1528 ~ 25674248010
      20Other0 Hz0 ~ 000
      Current System Time: Sat, Jun 12, 2021 21:19:59
        Mattferg93
        On top of this, I've replaced a splitter and another connector with brand new f type connectors and the problem persists.
