tedchen1
Jun 14, 2021Follower
My Neatgear cable modem router C7000v2 can't log on to 192.168.0.1 website
My Neatgear cable modem router C7000v2 has wired connection but has no wifi.
I would like to log on to website to fix this problem.
I can't get access to the log on website.
Please help
1 Reply
> [...] C7000v2 has wired connection but has no wifi.
Which you determined how, exactly?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot". Pay particular attention to the
"WiFi On/Off button with LED". Did you press it? Further reading
might not hurt, either.> I can't get access to the log on website.
"can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
