Wedtream's avatar
Wedtream
NETGEAR C6220 VPN Instructions?
Have a Netgear C6220 router and looking for instructions to add my PIA VPN to cover the whole house from my router, not just desktop traffic. Searched interwebs and this forum and dont see anything (maybe missed??).
Any help is apprecaited. Thanks!
  • FURRYe38's avatar
    I would review the spec sheet and user manual for VPN support. If you don't see anything mentioning VPN, it's probably not support ON the modem itself and you'll need to use VPN software on your devices.
    • Wedtream's avatar
      Wedtream
      Ahh ok... very new to this. Thanks for the tip. Will check.
