- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New - CAX30 Firmware Version 1.4.10.10 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
New Features and Enhancements:
• Stability Improvements
Download Link:
https://www.netgear.com/support/product/cax30.aspx#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/
enter your model number in the search box, and click the Documentation button on the product page.
NOTE: This upgrade is for the ROUTER portion of the CAX only. Modem portion Firmware upgrades are pushed down by your ISP. For more information, please see our https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-mod...
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX30
Hi, my CAX30 firmware seems to update on its own even after I downgrade it. Can I stop that. The new firmware isn't working on it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - CAX30 Firmware Version 1.4.10.10 Released
Hi, my CAX30 firmware (modem portion) seems to update on its own even after I downgrade it. Can I stop that. The new firmware isn't working on it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whats not working on it?
Did you perform a factory reset and setup from scratch after updating the FW?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
yes I did the factory reset & put in the firmware that works for me. I’ll start from the beginning. About a year ago when I got the CAX30 I had problems with it setting up a different ip address for each of my devices I was adding(have about 27 devices running). It would only do about 7 devices. So I called tech support & I ended up getting the engineer that works on them & he finally made up a custom firmware for me & it’s worked ever since then up until yesterday when it updated to a new version(1.4.11.2). But every time I put it back to my custom version that works it seems to update overnight. So hopefully someone can help me or I was thinking of just going with a separate router & WiFi system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try a factory reset and setup from scratch after the newer FW was loaded?
- Mark as New
- Bookmark
- Subscribe
- Permalink
keep my custom firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it normal for the configuration screen to read version 1.4.11.2 after installing this firmware?
Seems pretty confusing that the package is 1.4.10.10.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am experiencing a similar behavior. I have also had problems reserving ip addresses and hoped this update might improve that. When I loaded the update my firmware now reads 1.4.11.2 which seems very strange. The dhcp problems still exist and now I can't seem to re-load the previous firmware rev. The hourglass on the fw update page just spins and spins. I've tried several web browsers and computers. same thing..
The CAX30 is not the only Netgear router that has problems reserving ip addresses. There seem to be several threads on various router models with problems. It seems unbelievable that a company as large as netgear can't get their software in order. Very disappointing. My interim solution has been to use fixed ip addresses out of range of the router assignment pool on devices that need fixed addresses..
My CAX30 has also been periodically loosing all it's WIFI ssid configuration. I have a replacement unit arriving tomorrow. Hope it's better but I'm not very hopeful.
- Mark as New
- Bookmark
- Subscribe
- Permalink
By 'factory reset and setup from scratch' do you mean that we should not restore a previously stored settings file?
Also, does your installation cause the firmware level to be shown as 1.10.11.2 on the opening html configuration page?
I am concerned that the download package is not what it should be.
And Thanks,
sryan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Set up from scratch and do not load a saved backup from file.
Would you capture the screen on the modems page where you see this FW version at?
I'll get this to NG for review.
Thank you.
And Thanks,
sryan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, so far it hasn’t updated to the new firmware. So it’s working for me now all of sudden. Weird
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where did you get this version of FW from? I see it's not reporting v1.4.10.10...Most ENG builds a a beta from NG support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The engineer at netgear made a custom firmware for me & it works great.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When was this done for you?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Last year it was done after I was sent a brand new router, because they couldn’t figure out what the problem was. Even with the new router too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok.
Up to you however if you do update, let us know what you see and experience.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not much to go off.
What do you mean by "kept updating my router"?
Did you manually download and manually apply the FW update with a wired PC and web browser?
What doesn't work for you with this version of FW loaded?
@Fishing4me2 wrote:
That’s the firmware version that kept updating my router with, but it doesn’t work for me. So far my custom firmware is working great. Hasn’t updated on me yet
